sensor identification
I was doing an engine swap on my 97 civic ex d16y8 When i was taking out the engine i broke a sensor but i dont know what it is. It is located above the oil filter. there are two sensor above the oil filter and it is the sensor on the top
they should be side by side. if your looking at it like your changing your oil filter, the one on the right is your knock sensor, the left is the oil pressure switch
the one with the single wire to a feamle connector is your oil pressure, should be in a black rubber bell shaped boot. the other one is a knock should be a round plug.
slowerTHANmollasses
Nov 3, 2005 02:07 PM
