skill level to replace a wiring harness
Old Jan 1, 2009 | 05:50 PM
bob barker's Avatar
Default skill level to replace a wiring harness
my bike has been sitting for a couple of months b/c of cold weather. today was a nicer day so i decide to take it for a ride. when i tried to start the bike the fan came on and my gauge cluster was going crazy. i get the old flashlight out and look around to see at least 3 different spots where a mouse/rat ate my wire. i was thinking of patching what damaged wire i can see but the little basted chewed the wire down to the plastic plug leaving nothing to splice into and there could be damage i cant see at the moment.i have found a whole wiring harness for $50.
so the question is how hard of a job is this?
Old Jan 1, 2009 | 06:55 PM
EngineNoO9's Avatar
Default Re: skill level to replace a wiring harness
what bike? year? Normally shouldn't be too hard once you pull the fuel tank and have access to everything. Probably pull the air box too as well.
Old Jan 1, 2009 | 08:02 PM
bob barker's Avatar
the bike is a 2004 600rr. never pulled a fuel tank before, i will do some searching.
Old Jan 1, 2009 | 08:03 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
i would just rewire that one section. doing a whole harness just for that is alot of work...
Old Jan 1, 2009 | 08:33 PM
bob barker's Avatar
the varmint ate 3 different sections that i can see.
Old Jan 2, 2009 | 04:02 AM
MSchu's Avatar
My Name is Nobody
It's simply a plug and play opperation... BUT it does require that you know how to use simple tools and do some fairly extensive dis-assembly and Assembly work.
Old Jan 2, 2009 | 05:22 AM
alright thats a different story. well your gonna be pulling your airbox, gastank, all your front plastics.
Old Jan 2, 2009 | 09:39 AM
svrider's Avatar
if you know basic wiring work it shouldn't be to hard. Just make sure to heatshrink all connections once you are done patching it up.
Old Jan 2, 2009 | 02:30 PM
bob barker's Avatar
ok guys i will be doing this project in a couple of weeks since i have time on my side. i will try to post an update when the time comes.
Old Jan 3, 2009 | 11:45 PM
shipsaeki's Avatar
I would do the whole thing because you only see those 3 spots but later on down the line, there may be some you missed and you will be diagnosing an electrical problem, which are the worst.
Starscream
Honda Motorcycles
17
Aug 4, 2008 06:14 PM
Ls1 FD3s
Honda Motorcycles
Jan 25, 2006 08:31 PM
sshaikh01
Honda Motorcycles
Oct 2, 2004 03:13 PM
that_guy
Honda Motorcycles
11
May 16, 2004 01:53 PM
Arturbo
Honda Motorcycles
34
May 15, 2002 04:58 PM
