Please Help my 1990 accord starts wen it wants
Old Jan 1, 2009 | 02:52 PM
chad olson's Avatar
Default Please Help my 1990 accord starts wen it wants
My 1990 Accord was running real smooth but recently it just stoped runnin? It starts up wen it wants to, and wen it does start it dosnt rev past 3,000? Please help...why is this???
Old Jan 1, 2009 | 03:01 PM
96F22B1Accord's Avatar
Default Re: Please Help my 1990 accord starts wen it wants
Has it thrown any CEL's? This might be your first course of action.
Old Jan 1, 2009 | 03:12 PM
chad olson's Avatar
the engine light came on wen i redid the head gasket??? i made sure every connection was hooked up right....and wen the car was runnin smooth i always had to give it gas wen i started it and its fuel injection? But wen the car runs it runs rough and it dosnt pass 3,000 rpm
Old Jan 1, 2009 | 03:47 PM
GhostAccord's Avatar
Is your CEL still on?
If it is, what code is the ECU throwing?
You should never have to hold down the throttle to start a Fuel Injected car. Find out what cel you had and we may be able to help you with your problem.
Old Jan 2, 2009 | 09:28 AM
chad olson's Avatar
how do you read the cel's i don't no how to?? need some help!!
Old Jan 2, 2009 | 09:47 AM
craiger28's Avatar
On the passenger side at the kick panel under the dash you will find a blue male connector that has two holes in it. Get a paperclip or piece of wire to jump the two sides together. Once you jump this the CEL will blink. count the number of blinks and let us know.
Old Jan 2, 2009 | 10:58 AM
Default How to Read DTCodes
1.) Locate the blue 2 pin jumper plug. IIRC It is attached to a metal support under the glove box above the passenger's kick pannel.
Once you have found it you can pull it out of the retainer that it is in.
2.) WITH THE CAR OFF, insert either a 2pin connector clip, paper clip, or loop a thin enough piece of wire into both holes on the connector. This will short or close the loop telling the ECU to send the code to the MIL (CEL) on your dash.Basically you want to connect the two contacts together.
3.) Back in the driver's seat, turn the key to the 'ON' position. The CEL light will come on at startup, like normal, but it will then begin to flash.
**By counting the number of flashes, you can decipher the CEL #.
SHORT flashes are single digits (1/2 second)
LONG flashes are 10's (1 second)
You may have multiple codes, if there are multiple codes there will be a slight pause between the sets of code flashes.
Ex
short...short...short Pause long...long...short...short...short
In this example you would have a code 3 & 23.
Old Jan 2, 2009 | 12:44 PM
chad olson's Avatar
ok thanks man!! ill check it out and let you no????
Old Jan 2, 2009 | 01:07 PM
UCLA.lion's Avatar
I <3 My CB7.
join www.cb7tuner.com
Ryan2005accord
May 7, 2015 05:15 AM
Jeannie Lynn
Mar 17, 2015 07:36 AM
CTGrey06RSX-S
Jun 6, 2013 07:52 PM
termite1r
Oct 24, 2012 07:31 AM
novakane2778
Jun 16, 2008 11:26 AM
