Need help withEvap canister
the b16a has all the purge valves and map sensor mounted on the firewall and did not come with the engine. the original del sol had the map on the throttle body and the evap purge valve on the intake manifold can i just run a vacume hose from the evap canister into the throttle body or would that be bad
also could i just plug the throttle body and not have any hose on the evap canister? i live in louisiana so i dont need to pass emissions im just worried about performance
JSPECHB
Apr 30, 2003 11:40 AM
delslo
Mar 18, 2003 06:11 AM
