?WTF? no low beams, I cant figure it out!
Ok, so last night I went outside to start my 02 CRV because it was freaking cold. I turn on the light then I thought maybe I should turn it off so I did. I went back inside and when we were ready to leave I turned on the lights and nothing!!! High beams work so I drove with the high beams on. Any thoughts?
Every single light works, I made a trip 30 mins earlier to go get a pizza and the low beams worked and now it doesnt. I'm stumped.
Tested the bulbs its self by jumping them and both high and low light up.
I tried wiggling the wires and connectors.
I checked under hood and under dash fuses and relays that I thought I should of check, I even unplugged and switched around the R and L headlight relays.
Any fuses you guys recommend me checking? I searched all over google and everything and a lot of people seems to be having the same problem but no answer.
FRUSTRATON!!!
help.
FRUSTRATON!!!
help.
i would have to say it sounds like a bad headlight switch or the red/white wire at the headlight/signal switch might have a bad connection cause the connector to get burnt. also the wire will turn brown by the connector. the early 02 civics had a recall for this but i have been seeing other honda come into my dealership for service and i have used the parts for that recall to fix the problem. good luck.
let me know what you fined when you take it apart. you can also pm me.
--if it is the switch, the headlight relay wouldn't click would it? Going to use a dvom and test light on it when I get a chance. My relay clicks but I dont know if that would make a difference.
I'll let you know what I come up with.
OMG I fixed it. The plug in to the switch was burnt. I unplugged it to look jump it and I found it so I cleaned it out with a pick, wiggled some wires and plugged it in and ta-da, it worked. It was pure luck but hey it worked for me.
tchubs2K
Mar 27, 2017 01:01 PM
