Clutch cable help..
Old Aug 5, 2002 | 04:56 AM
FUP23's Avatar
New User
Default Clutch cable help..
I seriously cannot see how this is going to work.... b18a1 in a 88 Crx Si .....when i pull up on the release arm it reahces fine but it wont adjust down .....the cable holds the arm up ...you know what i mean ?? Am i doing something wrong here
Old Aug 5, 2002 | 05:25 AM
FUP23's Avatar
New User
Default Re: Clutch cable help.. (Devin17)
come on ..little help please ..i can pull up on the release arm and get it to work but it wont go back down because the cable is holding it up ....what am i doing wrong
Old Aug 5, 2002 | 05:31 AM
Jeff C's Avatar
which clutch cable are using
Old Aug 5, 2002 | 05:36 AM
FUP23's Avatar
New User
Default Re: Clutch cable help.. (Jeff C)
stock one as far as i know...
Old Aug 5, 2002 | 05:49 AM
Jeff C's Avatar
i think you need to use a 90-93 ls cable, at least that is what i was told and bought for my swap which is not in just yet though
EDIT: reread original post
[Modified by Jeff C, 9:49 AM 8/5/2002]
ricodemus's Avatar
I had to get one for a 90-93 teg for bseries swap.
Old Aug 5, 2002 | 07:32 AM
FUP23's Avatar
New User
Default Re: Clutch cable help.. (ricodemus)
well it worked with my b16 ..why wouldnt it work with b18 ?
OK....When i installed my clutch ..I want to make sure i had it facing the right way ...I had it so that the clutch was touching the flywheel surface ....Please tell me thats right
[Modified by Devin17, 11:36 AM 8/5/2002]
Old Aug 5, 2002 | 11:14 AM
Jeff C's Avatar
according to c-speed...
The disc can only fit one way into the pressure plate, so don't worry about messing that up.
heres a pic...
was the throw out bearing replaced? was the shifter arm and spring messed with?
i am just trying to narrow down the possibilities
Old Aug 5, 2002 | 02:32 PM
Doodoo's Avatar
Yeah thats right about the clutch.
The stock cable will work. I took off the bracket it goes into, put the cable in it, then bolted the bracket to the tranny. I only used it for about a week. It is much better with a 90-93 cable. More adjustment.
efrex
Nov 5, 2005 06:45 PM
user 72830283
40
Sep 22, 2005 12:06 PM
coot_er
May 24, 2004 12:12 PM
rextec
Oct 28, 2003 10:11 AM
turbohf
Oct 16, 2003 09:37 PM
