96 accord oil @ spark plug area
This morning I start the car without any problem. When I went to drive it, it bogged down, almost stall. I pop the hood and check and there is oil coming out from the spark plug area. The car never stall and could still drivable (short distance). Now the car is in driveway.
My friend suspect valve cover gasket. Does anyone have an idea of what else it might be before I start replacing more stuffs.
Thanks in advance.
Thanks in advance.
its the o rings!!! buy a valve cover gasket kit!!! comes with it all and you will be good! had the same problem before and it went away with that gasket kit.
Well, the car was throwing code also. So me and my friend brought it to midas and they pulled the code.
Turns out that #1 was misfiring and there is oil spill on #2. I have no idea why misfire have anything to do with oil coming out from the spark plug area. Anyways, they found out it was the distributor and cap and cleaned it....
denierlexiese
Aug 17, 2015 07:03 AM
TunesEK
Jan 15, 2009 01:35 PM
e_r_i_c_
Feb 15, 2006 07:08 PM
