dim blinkers
Old Aug 5, 2002 | 03:05 AM
DeLiRiOu5's Avatar
Default dim blinkers
so i got my sidemarker installed...
the problem is the driver side front corner and sidemarker is really dim when it blinks (the rear blinkers are fine) and my passenger side blinks just fine. so i changed out the light bulbs but still... same problem anyone have any idea what could be wrong? i'm thinking the wiring is fucked up somewhere but haven't had the time to check it out.
Old Aug 5, 2002 | 01:40 PM
Chiovnidca's Avatar
Default Re: dim blinkers (DeLiRiOu5)
Did you check your ground connections?
Old Aug 5, 2002 | 03:17 PM
DeLiRiOu5's Avatar
Default Re: dim blinkers (Chiovnidca)
not yet...
any other possible problems?
Old Aug 5, 2002 | 11:08 PM
paul9luap's Avatar
I just messed around with my sidemarkers recently. What type of bulb are you using for the sidemarker? I'm assuming it's the same small little wedge peanut bulb ( i don't know the technical name ). Also, check your connectors. Real electrical plastic connectors do wonders compared to crappy electrical tape splicing. Also, how are you wirering them? Currently, mine are set as turn signals only, so they blink at the same time as the bumper lenses. But for awhile, I had them as running lights with the headlights, and then alternating back and forth with the turn signal.
Shake and Bake
Jan 6, 2006 02:41 PM
Weapon_R
Nov 12, 2004 07:29 PM
InTeGrA B18b1
Jul 14, 2004 05:50 PM
RTW DC2R
Dec 3, 2003 06:50 PM
FalconMan
May 8, 2003 03:51 PM
