Stock fuel rail vs performance full rail
^ x2, its mostly for looks. Technically it holds more and in some mysterious way might keep the fuel .3425659% cooler but i've never seen a dyno sheet that shows they do anything
Stock Honda OEM (B-series fo example) fuel rails are just fine for anything up to 500HP. Once you break the 500hp barrier then you need to basically upgrade your whole fuel system...
