rev limiter?
well i allready know that im going to get bashed on for not using the search function but i dont have the time to sit here and dick around
do the stock 90 dx hatch with the d15d2 have a rev limiter? i am wondering this so i don't over rev my stock motor and blow it up.
all i need is a yes or no and maybe what rpm it hits at.
thank you all for looking at my post and helping me out.
why not try to see if you have one... my b16 would stop at 8500...
take a drive rev it up and if it doesnt stop around 7000 - 8500 you dont have one
unless its programed
I'm mainly asking this because my car dose not have a factory tachometer, and if i don't have a rev limiter ill just blow it up trying to find it.
the stock motor is the D15B2 as i stated above and there are no ecu mods or anything at all done to the motor of this car
From http://en.wikipedia.org/wiki/Honda_D_engine#D15B2
...one of the first links when you google "Honda D15B2"
D15B2
* Found in:
D15B2
* Found in:
o 1988-1991 Honda Civic GL/DX/LX
o 1988-1991 Honda CRX DX
o 1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
o 1990-1995 Honda Concerto (European Market)
+ Displacement : 1,493 cc (91.1 cu in)
+ Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
+ Rod Length : 134 mm
+ Compression : 9.2:1
+ Power : 92 hp (69 kW) @ 6000 rpm & 119 Nm @ 4500 rpm
+ Valvetrain : SOHC (4 valves per cylinder)
+ Cam Gear : 38 tooth
+ Piston Code : PM3
+ Fuel Control : PGM-FI Dual Point (OBD0)
+ Redline : 6500 rpm (6000 rpm honda concerto) 7200 rpm rev limiter
+ Piston Code : PM3
Jabbito
Nov 8, 2015 03:24 PM
thewrai6th
Aug 14, 2007 05:44 PM
