CEL obd0 b16a in a 1990 crx si
http://www.youtube.com/watch?v=u38J-ABqm4A
what code is this. i thought it was a tps. i replaced it and i still got this. it comes on like 10secs after i starterup.
Well you can't just slap on a TPS you need to calibrate it for .05 closed and 4.5 at WOT. Also it looks like you have a code 2 for secondary o2 sensor. Also have you reset your ECU since you replaced the TPS, the ECU will store error codes until power is removed from the ECU either by battery, unplug ECU or remove the hazard fuse.
loid
Oct 9, 2005 01:43 PM
Count Blah
19
May 26, 2003 04:43 PM
