91 Civic Hatch Shell wanna swap in a B16A OBD0 w/ Hydro LS tranny
I may get this 91 EF shell. It was dual point injection (as told by the seller) cable tranny, ect. I wanted to know wanna ALL would I need to be able to swap in this engine.
Coming with the shell
-body harness
-stock engine harness
-drive shafts
What I have
-first gen B16A (obd0)
-Multi point intake manifold
-Hydro LS tranny
-Radiator from my EK
-P30 ECU
I was told I would need mounts from a DA, some tranny mounts, conversation harness, resistor box, an battery stay, radiator stay. I don't know what else I would need. I could use some advice please. Thank you very much.
-body harness
-drive shafts
What I have
-Hydro LS tranny
-P30 ECU
This swap has been common for about 15 years now so everything you need to know is in the FAQ up top. 5 minutes of searching will answer all your questions.
use the faq up top, lots of info there, but for starters you will need the hydro trans conversion kit, i recommend the hasport kit, pricey but well worth it, and if searching gives you this much trouble i also recommend you contact rywire for your conversion harness if your car is a dpfi, you will need DA shift linkage cut and re welded or buy the hasport one with the mounts, also DA axles or buy the hasport axles.
og_hatch_90
Oct 15, 2005 09:53 PM
pzzed_off_bumblebee86
Oct 14, 2004 10:34 PM
