complete fully built swap turbo motor b18c1 block with 98 usdm type r head
up for grab is my fully rebuilt turbo motor...it has a fully built type r head with lots of work done to it...too much to list...if anyone is interested then i will provide the details...block is sleeved by darton or aebs not so sure...specs are 84mm with JE pistons and brian crower I-beam rods upgraded rist pins for aggressive boost...arp head studs and lol too much to list...these are the only pix i have for now....new ones will be posted tomarrow...if anyone who's interested i will provide a full detail about the motor and will give them all specs thats been done to the motor as in port flow of the head,work thats been done to the block and the head and the reciete for everything...incase your wondering, for transmission i have a jdm 96-97 spec type r lsd trans along with this fully built long block...lmk honda-tech my askin price would be 4K no lower...plz no low ball...i spent about 9k building this im losing as it is already...its been fully assemble by dg motor here in minnesota...valve adjustment has been done and block has been redecked to make sure nothing is worp or whats so ever...running skunk2 pro 1's cams on the intake and exhaust...holla...and if you view...plz bump
