no clutch prssure
Old Dec 31, 2008 | 12:18 AM
91crx-jace's Avatar
Default no clutch prssure
ok, i have a 91 crx si w/ b18b motor w/b16 cable tranny. i just finished the swap and went to try and drive it. no clutch prssure. and with the clutch in, it wont go in to gear, just grind. i push in the clutch and it stays to the floor. when i pull the clutch lever on the tranny, there is very little pressure. i pulled the tranny out and the lever is engaging the throw out bearing. im a lil confused. i bought a stock clutch/pressure plate/flywheel from an associate and thats what im using now. he said its off a DA. i have a ys1 clutch/pressure plate/flywheel and the dimmensions look the same as the DA set. could it be the pressure plate is bad??? any help would be appreciated.
Old Dec 31, 2008 | 05:50 AM
p10hlm's Avatar
Default Re: no clutch prssure
could you of installed the friction disk backwards?
Old Dec 31, 2008 | 05:56 AM
sirtef9's Avatar
That is not gonna happen. Can you go through the gears with the car shut off?
Old Dec 31, 2008 | 11:46 AM
88SeeOurEx's Avatar
after you added the tranny fluid did u bleed the clutch? and also u used the clutch alignment tool when putting the clutch on the flywheel???
Old Dec 31, 2008 | 11:58 AM
carnz98gsr's Avatar
its a cable trany, you don't bleed anything. check your cable tension. try moving it around some and adjusting the tension nut
Old Jan 4, 2009 | 10:51 PM
91crx-jace's Avatar
hey thanks for the help. it ended up being the wrong pressure plate. but after i finished the swap i wrecked my car four days later. lol.
top of 3rd gear+fog+slick road+dead end+no signs+gate=bad situation. lol
Old Jan 5, 2009 | 03:38 AM
jhammond_82's Avatar
Reject Papi
dude that sucks.
Old Jan 11, 2009 | 01:11 PM
Br1gHtDc2's Avatar
Banned
wow.. sorry to hear.
Old Jan 11, 2009 | 06:08 PM
kojack_0's Avatar
check the throw out arm. maybe its bent.
Old Jan 11, 2009 | 06:41 PM
p10hlm's Avatar
oh yeah why not?
read the entire thread
88 EF Hatch
Oct 7, 2009 10:39 AM
greensleeper
Jul 31, 2002 02:33 PM
slikciv99
Nov 20, 2001 11:03 AM
