valve cover nut won't come off!! ?
Old Dec 30, 2008 | 10:51 PM
butter99's Avatar
Default valve cover nut won't come off!! ?
I must have tightened my valve cover nut too tight and now it just spins!
The stud may be spinning somehow
but the nut is defenitely spinning when I try and get it off
I have tried vice grips By pulling the nut and turning at the same time
I have tried pushing the ratchet as i turn
I have used a screwdriver to pry the valve cover up while turning the nut
How do I get this dumb nut off? ? ? So I can get my valve cover off!
Old Dec 30, 2008 | 11:02 PM
butter99's Avatar
Default Re: valve cover nut won't come off!! ?
bump
Old Dec 30, 2008 | 11:12 PM
92SR4WS's Avatar
did you break the studs off...
Old Dec 30, 2008 | 11:15 PM
Paul-R's Avatar
lol well you fcked up ...
Old Dec 30, 2008 | 11:17 PM
butter99's Avatar
ya i screwd up real good, I don't think I broke the stud because I still can't get the valve cover off.
Ya I don't get it cuz if the nuts is spinning then the stud must be spinning but nothings coming out SO I don't get it.
ooo unless the bolt thats between the block and the valve cover started spinning... ugh
I still can't come up with another way to get the nut off.
Old Dec 30, 2008 | 11:27 PM
TruNinja619's Avatar
well.. the only thing I can think right now is to drill through that nut and stud.
Old Dec 30, 2008 | 11:28 PM
butter99's Avatar
ya that's all I'm coming up with too.
Old Dec 30, 2008 | 11:35 PM
92SR4WS's Avatar
Pry it real hard? lol that is ridiculous I broke my stud before and I just pulled it out with my hand...
Old Dec 30, 2008 | 11:43 PM
butter99's Avatar
hmm ya its kinda wierd. I'll try some prying on the valve cover I guess then if no luck I'll try some cutting. I already broke 1 stud UGH! So this will only be one more lol I'll have to buy a few. I think its 7 ft lbs or so I think I got the hang of it now.
Old Dec 31, 2008 | 04:33 AM
PirateMcFred's Avatar
Get a little chisel and jamb it under the nut as best you can and apply as much pressure you can along the axis of the bolt while turning the nut. If you're lucky you can get the nut to catch what's left of the threads and it might come off. If not then grind/drill it off and replace the stud/nut later. Reinstall using a torque wrench so that nothing strips next time. If you used a torque wrench before then apply a little oil or anti-sieze compound to the threads before tightening the nut next time.
Pirate
Old Dec 31, 2008 | 08:12 AM
Lude Acts's Avatar
Take a dremel with a small cutting wheel and cut the nut in half vertically. It should then fall off in 2 pieces. Then you have to replace that stud, but you'll have to do that anyway.
Old Dec 31, 2008 | 11:10 PM
butter99's Avatar
I did finally just cut and drill the nut out. The nut was stripped and spinning not the stud. But by drilling into the nut I messed up the threads a little on the stud so I need two studs and 2 nuts..no big deal.. thx all
Old Jan 1, 2009 | 12:19 PM
lude98SH's Avatar
this happened to me a few months back. I ended up cutting the nut in half with a dremel and replacing the stud.
Old Jan 1, 2009 | 09:22 PM
Lude Acts's Avatar
^^^^^^I just said that.
Old Jan 1, 2009 | 09:36 PM
butter99's Avatar
HAH thanx
Old Jan 3, 2009 | 08:06 AM
lude98SH's Avatar
Old Jan 3, 2009 | 08:07 AM
lude98SH's Avatar
and .................
Old Jan 3, 2009 | 02:11 PM
OneRedLude's Avatar
Once you replace that part, remember that the nuts on the valve cover should be torqued down to 8.7 foot-pounds in 2 or 3 steps. Don't wanna distort the valve cover now do we?
Old Jan 3, 2009 | 07:49 PM
butter99's Avatar
correct I will torque it to spec this time!
Import Prelude
Apr 18, 2007 02:50 PM
MI4$DC5
Jan 15, 2007 08:03 AM
99teggsr
Apr 17, 2005 09:54 AM
kreamy
Oct 2, 2003 06:43 AM
Dopamine_44
Nov 13, 2001 01:27 PM
