flasher / sunroof problem
I got a 89 civic SI, and I pulled out the cluster to put a needle on the gas gauge.
When I put it back the sun roof doesnt work, and if i signal to the left or put on the hazards it makes a loud "buzz" noise, and the sunroof wont open or close, it makes a low "buzz" noise.
Has anyone ran into this problem before that can help me?
Thanks.
Thanks.
First thing you should do is check your fuses. I dont remember if those are ran together or not but you need to check them just incase. The second thing you need to check is your wiring. Make sure you dont have any wires grounding each other out. Should be 1 of the 2 things...good luck.
I got a similiar problem, When i hit the turn signal they buzz, And all the needles on the custer bounce sometimes, and the water temp needle rises on its own. Car is not overheating though.
Probably not the flasher, so what could it be?
EG-SIXV-TEC
Aug 1, 2010 11:00 AM
