so iam boosting my stock si crx
i was just wondering (because iam sure ther's a few peeps on here that have done the same) how much power i will prolly make at just 8psi on a stock 90 c-rex si, using mostly all mitsu turbo stuff except the manifold.
thanks man thats all iam really wanting right now.....just something to shut my mustang buddies up and the few other "quick" cars around where i live.
also another quick question.... i did a cmpression test on mu car and got the folling cyl#1-171psi.
cyl#2-174
cyl#3-172
cyl#4-170
now the haynes anual says it should be around 128psi...........whats up?
cyl#2-174
cyl#3-172
cyl#4-170
carbon build-up in the combustion chamber? Someone sliped in P29 pistons?
Only problem with the stock motor making bigger power is the bottom end. I know people are going to say they've done it, but some have had problems, including myself. After only one summer, and making 170whp, i threw a rod. Those B16A6 engines are old now, personally, i would go with a very inexpensive B swap like a B18A which is also older, but "much" stronger, and can handle and make way more power.
