..where does the oil go into on the top of the transmission?!?!?!?!
Old Dec 30, 2008 | 08:30 PM
Peter_404_21's Avatar
New User
Default ..where does the oil go into on the top of the transmission?!?!?!?!
help
Old Dec 30, 2008 | 08:32 PM
Davus's Avatar
Default Re: ..where does the oil go into on the top of the transmission?!?!?!?!
Is this for an automatic or manual? With a manual, you can unbolt the Vehicle Speed Sensor, it's a 3-pin plug on top of the manuals, and pour fresh MTF in that way. There's also a drain plug at the bottom that you use a 3/8 ratchet (with nothing on it but maybe an extension) to open.
For automatics you'll use the dipstick hole with a good long skinny funnel.
Old Dec 30, 2008 | 08:38 PM
Red_Army's Avatar
make sure if its a mans to use the higher fill plug or it'll be a waste if you try to fill it in the drain plug.
same thing just 3/8 ratchet no socket.
Old Dec 30, 2008 | 08:41 PM
z6hatchboy's Avatar
i tried the vss thing once and it kind of came apart? Theres a 17mm bolt in the side of the tranny above the fill plug a ways. I stick a hose in there and fill it that way, you have to be quick though to get the bolt back in
Old Dec 30, 2008 | 08:45 PM
Davus's Avatar
I broke mine first day I had the transmission, turns out those bolts do not like torque at all! Just a hand ratchet and SNAP, the base broke. Still mostly works, get a little fluctuation is all.
Old Dec 30, 2008 | 08:54 PM
z6hatchboy's Avatar
that sucks man, but most small ones like that, that hold sensor are tedious lol
civicboy420
22
Aug 7, 2014 01:20 PM
vannak_5415
Oct 6, 2008 05:34 PM
Rex89
16
Jan 2, 2007 06:24 PM
89crx23
May 23, 2005 10:19 PM
maivietla
Mar 22, 2005 07:02 PM
