i do not have a external antenna so where is it located
Old Dec 30, 2008 | 07:49 PM
khronicboy420's Avatar
Default i do not have a external antenna so where is it located
i have a 95 honda accord lx 2dr. now there is no antenna on the outside of the car and no hole where it used to be, and i have seen alot of accords (and other cars) that do not have a antenna on the outside of the car.i wanna hook up my satalite radio but i need to know where the antenna is located thanks for any help
Old Dec 30, 2008 | 07:57 PM
thatasiankidtony's Avatar
Default Re: i do not have a external antenna so where is it located
if you don't see it, it's on your rear windshield.
Old Dec 30, 2008 | 08:10 PM
endless22's Avatar
maybe some one shaved it or if not its probaly in your windshield
Old Dec 30, 2008 | 08:12 PM
P_Adams's Avatar
It's hiding out mascarading as your rear window defogger. The upper-most grid lines act as the antenna.
There may be some confusion here (perhaps on my part). Since satellite Radio works on a much higher (different) frequency, I don't believe they are ment to be hooked up to the OEM am/fm radio antenna.
You might want to get confirmation on this. Belkin's Satellite Antenna looks much like a GPS antenna, a 1.5" square x .25" Plastis box.
Refer:
http://www.google.com/products/catal...ult#ps-sellers
P
Old Dec 30, 2008 | 09:22 PM
YeuEmMaiMai's Avatar
ALL 94-97 coupes have the antenna located in the rear glass right above the defroster. All 09+ accord have them in the rear glass
Old Dec 31, 2008 | 04:32 AM
high_society's Avatar
Sat radio set ups usually come with a seperate antenna, it looks like either a little black square or a shark fin. You stick them on the roof of your car with double sided tape and run the wires through your headliner to your h/u. Don't try using your cars factory antenna for sat radio, that **** won't work and you'll probably break something.
Old Dec 31, 2008 | 05:08 AM
mikey012's Avatar
you dont even have to put it on the roof.mine sits on my dash by the defrosters and the reception is perfect
Old Dec 31, 2008 | 06:15 AM
Or do that^
Then when you get tired of paying the sat radio bill, it will be easier to take it out of the car.
Old Dec 31, 2008 | 07:23 AM
Conan's Avatar
Refer:
P
I think he may be trying to find the antenna to hook up an FM modulator so his satellite radio will play through his factory one, but I could be wrong. If thats the case just unplug it behind the factory stereo.
Old Dec 31, 2008 | 07:30 AM
word, didnt think of that.
Old Dec 31, 2008 | 05:55 PM
Conechaser's Avatar
Actually some newer Satellite radios tie into the factory antenna. My brother got a new one for his Tractor Trailer because his other one broke and it ties into factory antenna AND still has it's own antenna not really sure why.
Old Dec 31, 2008 | 07:58 PM
Conan is right im trying to hook up a fm modulator so it will play through my deck, my satellite has to hook up that way. i thought about just hooking it up to the antenna that runs to the back of my radio (i dont have to cut anything it just hooks on to it) but i didnt know it if would work the same. and ya it also has the antenna with a magnet that goes on to the roof. thanks for all the help.
clowery89
May 11, 2010 10:35 AM
tjjm36m3
Mar 10, 2009 08:34 AM
accorddog
Dec 17, 2008 12:20 PM
<StevieG>
Honda Civic (2001 - 2005)
Mar 7, 2008 10:29 AM
phateless
Jan 22, 2003 09:02 AM
