Replaceing stock intake manifold with 96 Civic Manifold
I just got a new civic ex manifold from a manual 96 civic, i heard that they have way better flow than the other manifold, what would cause any problems with installing it?(vaccum hoses, AIT sensor)... Oh im intalling it on my 88 CRX with a jdm d15b vtec, It says P2K on the manifold
the pcv system is a little different. im not exactily sure what parts you will need but im sure somebody will stop by and fill ya in
Pretty sure the IAT probe for the Y8 is located in the rubber intake tube...which is different from the Z6 which is screwed into the manifold.
Not sure how(if) the D15B IAT is attached. Anyone help me out on that one?
Might be something to look at.
You'll have to swap a few plugs like your iac plug and a couple other sensors have different plugs. Other than the IAT sensor being in a different postion it's all pretty strait forward. The map sensor is on the throttle body on the y8 (and z6 as well) so you can delete it from your firewall.
Iloveyourhonda92
Mar 25, 2010 01:39 PM
meagainsttheworld
Aug 29, 2007 02:06 PM
LilCivic04
Jul 23, 2006 10:47 PM
