SOHC gurus! i need help iding an int mani..
Old Dec 30, 2008 | 06:58 PM
sykotik sol's Avatar
Default SOHC gurus! i need help iding an int mani..
ok, basically this car has been pieced together with alot of different drivetrain piecesbut i need help identifying this int mani or fuel rail specifically...
specs as i know:
89 civic si hatch
96 d16y7 longblock
88 dx trans
but its missing the end nut for the fuel rail/fuel line and i cant seem to get the right one..
i found 1 that threads on but wont tighten completly and leaks fuel, the other one i ordered for a 96 dx and threads are totally wrong and wont thread on...
please if u can help please point me in the direction of the correct fuel rail nut..
heres some pics
Old Dec 30, 2008 | 08:25 PM
93turbo16's Avatar
Default Re: SOHC gurus! i need help iding an int mani..
Do you have crush washers on both sides of the fitting?
Old Dec 30, 2008 | 09:46 PM
dcvt16's Avatar
the manifold and rail are from 88-91 SI. order one or find one a the junk yard and make sure you use a crush washer oon each side of the banjo.
Old Dec 31, 2008 | 10:17 AM
does a crush washer look jus like a regular washer? cuz i ordered 2 new washers when i ordered the end nut for a 96 civic...
are they the same, cuz if so yes i have washers on bot sides of fuel line fitting but banjo nut wont tighten...jus wants to keep goin around..
Old Dec 31, 2008 | 04:57 PM
dcvt16's Avatar
dont use the 96 cap. you need 88-91 si. but if i came with the washers they should work.
lickety_britches
Apr 22, 2009 06:19 PM
chirp the 1-2
Aug 31, 2005 08:11 AM
shivern
Dec 14, 2004 10:21 AM
Jdmglenn
Oct 8, 2004 04:49 PM
