Clutch cable stretching
Old Dec 30, 2008 | 03:05 PM
88'CRXsi's Avatar
Default Clutch cable stretching
Ok i recently did a B16a2 swap in my car and it has a GSR Hydro tranny on it so i got the Hasport cable to hydro conversion kit thinking everything should be fine. So far this is the second cable I've replaced because it keeps stretching. I did a couple online searches trying to see if theres a way I can prevent this from happening. Some people say its the hasport kit. Does anyone know if theres another kit that won't cause it to stretch or any clutch cables that are stronger?
Old Dec 30, 2008 | 03:27 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Clutch cable stretching
what clutch are you running? if you are running like a stage 3+ or something like that, you should do one of 2 things: downgrade your clutch so you stop breaking cables, or upgrade your clutch release bearing system to be fully hydraulic. Tilton makes all the gear you need to do it.
its all about using the right parts for the job. a stage 3 doesnt belong in a car under 400 hp.. and if you have more than that, well, you should know that a cable clutch is not the way to go.
Old Dec 30, 2008 | 03:33 PM
88'CRXsi's Avatar
it has a ACT strip/street clutch. I'm not sure what stage that is it just came with the swap
Old Dec 30, 2008 | 03:48 PM
EFRue57's Avatar
i used the hydro to cable conversion on my gsr swapped crx and never had a problem with it. i had an act stage 2 clutch.
Old Dec 31, 2008 | 10:04 AM
Hasport's Avatar
try using a 90-93 Integra cable
use an OEM Honda cable
they are around $30 from the dealer
Old Dec 31, 2008 | 01:50 PM
88'CRXsi's Avatar
The first cable i had was OEM and it stretched really bad in like days after the swap. The one on there now is the one that was made for the B-series in the EF (so basicly its a OEM CRXsiR cable) but if this one gets any worse i'll try then integra cable and see who it works.
kid_02131
12
Nov 6, 2013 05:32 AM
Kid_SiR
Jul 16, 2011 12:10 PM
Tycoon
Jan 28, 2007 10:09 AM
88crxdxfastwhip
Sep 4, 2005 09:18 PM
fausz
12
Dec 31, 2004 07:37 AM
