tranny clearance?
Old Dec 30, 2008 | 11:06 AM
Skirts's Avatar
Default tranny clearance?
I have gsr in my 91hatch and im running eibach spring and when I put the motor in I could barely press down on the front end and the transmission would hit the radius rod? how can i get more clearance? I have raised it up for the time being but dont like the way it looks.
Old Dec 30, 2008 | 03:47 PM
EFRue57's Avatar
Default Re: tranny clearance?
what mounts do you have? some mounts make the engine/tranny sit lower in the engine bay. also, what struts do you have? your struts will make more of a differnce than your springs when it comes to how bouncy it is. if you get a set of adjustable struts this could help solve your problem.
I had an ls swap in my crx using Hasport monuts and had eibach springs and used both kyb agx struts and koni yellows and never had a problem with the tranny hitting the radius rod.
Old Dec 30, 2008 | 04:26 PM
ludesrv's Avatar
I had the same problem on some cheap mounts. I took off my crank pulley and got the last 2 pulley machined off for 20$. Solved all my problems. I only ran the alternator tho.
Old Dec 30, 2008 | 05:56 PM
Skirts's Avatar
the mounts are billet avid mounts i believe. my struts are tokico and its not bouncy its just a half inch away. and my pulley is a ctr pulley and its fine
Old Dec 30, 2008 | 06:03 PM
~sp33~'s Avatar
EFB055
Do you need power steering and aircon?
Old Dec 30, 2008 | 06:23 PM
intense4thgen's Avatar
i run avid mounts and my tranny is not hitting at all, im dumped to the weedstoo ?
R91Si
Apr 8, 2007 04:25 PM
HackAbuse
Mar 18, 2007 08:35 AM
Jamied
10
Mar 29, 2006 06:31 PM
B16CRXT
Jul 19, 2004 01:57 PM
