8 injectors on hondata????
Old Dec 30, 2008 | 09:43 AM
sgnlab's Avatar
Default 8 injectors on hondata????
http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
seen this today on ebay is it even possible?
Old Dec 30, 2008 | 09:50 AM
mtber's Avatar
Default Re: 8 injectors on hondata????
"The second set of injectors will engage when you hit Vtec thru the injector harness coming directly from this ECU"
Made me laugh a little.
My bet would be that they simply piggybacked the power/signal from the original injector outputs to try and sell the ecu as something special.
Old Dec 30, 2008 | 09:58 AM
sgnlab's Avatar
I figured that! But Hondata has to do something we need some 8 injector action out of the s300!
Old Dec 30, 2008 | 03:51 PM
sander's Avatar
2.7(p/t)
Id be careful with that, the drivers may not be able to handle two sets. That is asking alot of the computer.
Old Jan 1, 2009 | 03:10 PM
quicksilver1689's Avatar
i ♥ snails
yeah injector drivers might take a poop
Old Jan 1, 2009 | 04:33 PM
boosted hybrid's Avatar
That is actually my old 8 injector ecu that was done through Raver motorsports. It uses another set of factory injector drivers that are powered via vtec solenoid on the board. When vtec is turned on, the secondary set of injectors turns on as well. It works really well actually. You just have to scale the secondary vtec fuel map to compensate for increase fuel flow from both sets. Raver motorsports did a bunch of those ecus for the edelbrock 8 injector turbo kits they were selling. Its actually really reliable since the injector drivers are OEM honda, but both sets of drivers are saturated.
Old Jan 1, 2009 | 04:40 PM
SovXietday's Avatar
^Neat, how is tuning the crossover with that though?
Old Jan 1, 2009 | 04:49 PM
Pretty decent if you have the secondary vtec fuel map scaled properly for the combined flow of the injectors. There is still a quick "rich" blip on the crossover but you cannot feel it. I would just as soon switch over to aem ems and run 8 injectors in staged control. Much more control over secondary injectors, and pretty simple to set-up. You can phase the secondary set in via load/rpm just like the main VE map.
Old Jan 1, 2009 | 09:06 PM
sander's Avatar
2.7(p/t)
Oh ok, thats a pretty cool idea!
Old Jan 6, 2009 | 08:01 PM
i ♥ snails
stupid 08
hyboost
Engine Management and Tuning
Apr 29, 2011 05:09 AM
IntegraG2
Mar 23, 2009 05:17 AM
b18psi
Jul 2, 2004 02:24 PM
lsturborex
Aug 12, 2003 03:43 PM
madman604
Feb 11, 2003 09:45 AM
