Accord Fuel Pump
Old Dec 30, 2008 | 08:12 AM
ahondaowner's Avatar
Default Accord Fuel Pump
1990 Accord - Tank has been dropped on shop floor, fuel pump removed. Wired pump directly to the battery and hear a whining sound. No fuel is coming out of the pump. Can the pump fail and still make the sound?
Old Dec 30, 2008 | 10:36 AM
P_Adams's Avatar
Default Re: Accord Fuel Pump
Yes, particularly if it's been run dry before.
Either the pickup is clogged / blocked or the Pump is toast.
Make sure there is no indication of impact damage to the tank's bottom. If it gets pushed up, it could (and often does) effect fuel pump operation.
P
Old Dec 30, 2008 | 11:14 AM
I just thought it odd to stop. The problem started when I discovered a fuel leak near the tank. I removed the tank and replaced the fuel lines. Before reinstalling the tank started the car to look for leaks. Everything ok. Installed the tank and then it would not start. Removed the tank to look for kinks in the fuel line. No kinks. Checked the voltage coming to the tank (thinking it is a main relay issue). Around 3 volts. So I connected a test wire directly to the battery and disconnected the fuel line directly on top of the tank. Definately hear the pump run but no fuel coming out of the pump.
Old Dec 30, 2008 | 11:34 AM
P_Adams's Avatar
Try changing the polarity when you retrace your pump test. It's a DC motor, so it could (concievably) run in reverse too.
Old Dec 31, 2008 | 08:20 AM
The polarity was reversed. Pump works. Back to the original problem with the relay.
Thanks for the help
Old Dec 31, 2008 | 09:48 AM
P_Adams's Avatar
Thanks for the help
Lol, S**t happens I guess.
Glad I could help.
P
ULNAFARKIN
Jul 19, 2015 02:49 AM
Kwish
Classic Hondas
Apr 23, 2012 01:01 PM
joeyt
Honda Civic (2001 - 2005)
10
Dec 24, 2008 10:40 AM
lmananT
Jun 4, 2008 10:56 PM
94teggyls
Jun 14, 2003 09:01 PM
