iacv question
Old Dec 30, 2008 | 07:18 AM
89CivicHb1's Avatar
Default iacv question
ive searched alreayd and could not find anything about if the iacv gasket is leaking air will that make the cars idle fluctuate? because if i unplug the wires the car will idle lower in rpms because the iacv is not working so if anyone can help me out that would be awsome Thanks.
Old Dec 30, 2008 | 07:21 AM
D16SiHatch's Avatar
Default Re: iacv question
If its dirty/clogged and/or if the seal is bad you will get idle fluctuations. after swapping to an xs power intake manifold i had a surging idle and since i knew the iacv hadn't changed at all i finally figured well hell it won't hurt to replace the little seal in there. sure enough i replaced it and just like that the hunting idle was gone.
Old Jan 1, 2009 | 04:46 AM
89CivicHb1's Avatar
were did u get the seal because i cant find it anywhere i was thinkin of putting rtv on there but i would rather use the right thing
Old Jan 1, 2009 | 05:58 AM
D16SiHatch's Avatar
i picked it up from a local honda dealership parts department.
Old Jan 4, 2009 | 10:12 AM
89CivicHb1's Avatar
ok i changed the little seal on the iacv and it did nothing so then i took my intake off and i plugged the whole inside with my finger on the top hole and my car idle's perfect not the Fast Idle Thermo Valve but im pretty sure its the whole that goes to the iacv so does that mean my iacv is bad?
Old Jan 4, 2009 | 11:00 AM
absinthminded's Avatar
When the car is fully warmed up, plug the bottom hole in the tb. If there is a lot of suction then you need to fix your fitv. Its easy to do yourself.
RinzEG6
Nov 24, 2014 12:02 PM
dc4b20
22
Dec 3, 2012 09:54 PM
Tytank7
May 8, 2008 11:29 AM
FloGgY
Apr 12, 2008 01:13 PM
byronl
Dec 20, 2006 05:29 AM
