crank pulley bolt .. how do i get it off?
Old Dec 29, 2008 | 09:50 PM
pjr710's Avatar
Default crank pulley bolt .. how do i get it off?
i have to replace my crank seal b/c its leaking. my uncle at honda usually does work for me and he uses an impact wrench to get my pulley bolt off.
i dont have one and i dont have that special tool. is there anyway i can get the bolt loose using the tools that i have?
p.s. i know this is asked a lot, but i rather smash my face off the ground right now than to use h-ts shitty vb search
Old Dec 29, 2008 | 10:04 PM
dcvt16's Avatar
Default Re: crank pulley bolt .. how do i get it off?
big f-ing impact is usually best.
Old Dec 29, 2008 | 10:09 PM
pjr710's Avatar
am i sol if i dont have an impact gun or that tool?
Old Dec 29, 2008 | 10:31 PM
dcvt16's Avatar
well, ive tried several with out with not much luck. is the engine still in the car and running? if so just go to a local mechanic shop or tire shop and give em a few bucks to break it loose and snug it back on. thas what ive done when i had no access to air and a decent gun.
Old Dec 29, 2008 | 11:13 PM
pjr710's Avatar
then u drive back with it loose?? sounds like a recipe for disaster
Old Dec 30, 2008 | 07:45 AM
srmofo's Avatar
no you dont drive with it loose, you justdont have it uber torqued anymore...they just snug it backup with a rachet, then you can unsnug it when you get home, if you dontwant to half *** it than just buy the right tools
Old Dec 30, 2008 | 08:33 AM
pjr710's Avatar
i'm probably gunna pick up the tool, i saw it for like 24, thought it was like 70
Old Dec 30, 2008 | 09:42 AM
dcvt16's Avatar
exactly. its not like its gonna come out if its tight. its just not going to be so tight that you need special tools.
buying the tool is cool, but you still need a BIG breaker bar. and its still kinda a pain.
but let us know how it goes.
Old Dec 30, 2008 | 12:33 PM
nub's Avatar
nub
My timming belt broke on my way home from work about a week ago so I was in the same predicament. Found this searching the forums, http://honda.lioness.googlepages.com...eyholdingtools. I had a scrap piece of angle, drilled two holes, found two long bolts and a short cheater on a breaker bar and the bolt came loose really easy. It took me longer to jack up the car and put it on jackstands than it did to make the tool and break the bolt loose.
Old Dec 30, 2008 | 12:36 PM
Rotten Egg's Avatar
u can put the ratchet on with an extension that hits the ground then crack it slightly...it'll break it loose then after ur done get it as tight as u can then take it to get torqued (it'll be ok for a short drive)
Old Dec 30, 2008 | 06:11 PM
JDM94HATCH's Avatar
the time i tried to take off my crank pulley bolt without the right tools it cost me 3 craftsmen ratchets,2 pro pain torches , a couple of 1/2 19mm sockets and almost my friends leg!!! but thats a whole other story lol another friend of mine lent me the tool the ****ing blot came right out with no problem!! I bought mine off the the matcho truck..very niccce
barrera
Oct 11, 2010 07:17 AM
DaKINE-Ek
Aug 14, 2006 05:22 PM
snowman0520
Jun 27, 2005 09:04 AM
4drDA
Oct 25, 2004 07:06 AM
Padawan
Jul 26, 2001 06:13 AM
