LS/VTEC Idle Problem **VID**
Old Dec 29, 2008 | 06:15 PM
keons5's Avatar
From: Grand Rapids, Michigan, United States of America
Default LS/VTEC Idle Problem **VID**
I know there are probably posts on this every day, but I searched and didn't find anything to be like my problem. If someone has a problem with this post, please delete it.
So I've got a problem with my LS/VTEC idling correctly. The problem has slowly been getting worse over time, so I don't think it is electrical. The car ran great all summer with the build. I've checked for vacuum leaks and have unplugged sensors looking for any sign of change. I cleaned the FITV and that helped a lot, before that it idled at about 3k. There was a check engine light on prior to cleaning the FITV. However, currently there is no check engine light. The FITV was pretty dirty so should my next move be to clean the throttle body? Any input would be greatly appreciated. I'm just confused because I have no experience dealing with something like this.
The problem: The car starts at 2k, drops down to 700, then bounces up to 1500 and continues to idle at 1500. If I rev it, it goes up and drops down to 700 then bounces up to 1500 and stays at 1500.
Video:
http://www.youtube.com/watch?v=JIAYE6l3-qo
Thanks,
Old Dec 31, 2008 | 12:26 PM
mouab18c1's Avatar
Default Re: LS/VTEC Idle Problem **VID**
check for vacuum leaks....check if your tb cable is sticky...also check your timing...and if you want poor some brake fluid down your vacuum hose line by your brake fluid container that goes to your intake manifold..then rev your motor...a **** load of smoke will come out your exhaust but is a simple way of cleaning your motor...
Old Dec 31, 2008 | 12:46 PM
killerpenguin21's Avatar
i would NOT do that
whats the motor setup and EMS? do you have a way to check the tps reading?
have you checked your grounds? checked the coolant? (this has caused me ahigh idle many times)
Old Dec 31, 2008 | 02:19 PM
mouab18c1's Avatar
Originally Posted by killerpenguin21
i would NOT do that
why not? i do it all the time...cleans all the shyt off my pistons....its fast easy and works all the time...
Old Jan 2, 2009 | 07:53 AM
AlphaQup's Avatar
Bump. I'm having the same problem on my LSV.
Old Jan 2, 2009 | 08:54 AM
spectacle's Avatar
The video and your description of the problem don't match.
The tach rests at 1k. When you started the car, it dropped down to 1500. When you rev'd, it went up then dropped back to 1500. If the needle was unmolested, that would equal an idle of 1k which is expected for a cold motor. A warm motor would drop down to maybe 700-800rpm.
So based on the video, I don't see a problem.
Old Jan 2, 2009 | 11:46 AM
paton5g's Avatar
you may just have a sticky throttle plate. you said you were going to clean it. have you? look at that after you've done what the others have suggested. carb cleaner and an old toothbrush does a nice job...
Old Jan 3, 2009 | 03:57 PM
tech7427's Avatar
either sticking throttle cable or too tight and or you said you cleaned ur fitv? you sure it wasent your iacv? do you have coolant lines under ur tb that run to the fitv? if you do id say take it apart and screw the wax pellet back in.
Old Aug 15, 2009 | 03:52 PM
keons5's Avatar
I thought I would bump this up. I haven't been able to fix it yet. Any responses would be awesome.
Old Aug 15, 2009 | 03:58 PM
StolenTeg's Avatar
Why is your rpm gauge stuck at 1k?
Old Aug 15, 2009 | 05:06 PM
keons5's Avatar
I don't know. It's always been like that.
Old Aug 16, 2009 | 06:51 AM
orioncivic's Avatar
check your iac valve it may be gummed up and keeping the idle from smoothing out like it should. also clean your tb its easy to do and when you have it off look to see that the plate closes all the way.
Old Aug 16, 2009 | 07:48 AM
StolenTeg's Avatar
How do you know your gauge is not screw up if it stuck at 1k while it should be at 0?
Old Aug 16, 2009 | 07:52 AM
TypeRMonster's Avatar
I'm thinking the same thing, if ur gauge starts off at 1000 from the gate then EVERYTHING...good idle or not is going to be off. From the sound of your car at idle I don't hear anything largely wrong with it..I'd address that gague first and see if it misbehaves then..as of now I see absolutely nothing wrong with your car.
PhilMac
Jun 17, 2007 02:09 PM
FAWKeveryb0dy
11
Nov 6, 2005 11:47 AM
psyonicdeath
Jul 1, 2005 07:25 PM
99silverbullet
Apr 25, 2003 07:54 PM
