Car has no juice..please help
Old Dec 29, 2008 | 11:12 AM
KRZRICAN's Avatar
Icon2 Car has no juice..please help
my car was runnin good until i saw smoke comin out of the dash..i have a 89 sedan with a 95 z6 1.6 sohc vtec.i have power on the motor bay and sum power on the fuse box under the dash..the car wont crank,no power window,lights radio etc.what can it be?i took the dash off to see if some cables were cut or burnt..i didnt see anything..please i need help..when i turn the switch for the lights,the main relay clicks..but nothing.and soo on.do i have to replace the wiring under the dash or did my ecu got burnt?please help..my email is krzrican@hotmail.com or call me.. east coast 856-405-7905..thanks..any help is appreciated..
Old Dec 29, 2008 | 11:23 AM
KRock459's Avatar
Default Re: Car has no juice..please help
ECU wouldnt cause what you are discribing, lights would work and engine would crank but not fire if the ECU failed. Sounds like a main power feed/fuse or ground failed. Check the main fuses under the hood to ensure they are OK first, next check the large white wire on the key harness to see if it has power. If it does, start checking grounding points.
Good luck!
Kirk R
Old Dec 31, 2008 | 08:32 AM
KRZRICAN's Avatar
THANKS..i'll do that..cause some fuses dont have any juice and sum does.how can i know if its the ground?and where under the dash?
jtbob24
Honda Civic (2001 - 2005)
Jan 14, 2015 09:20 PM
eagleclawracing
Nov 12, 2012 10:52 AM
FukinCrx
Jul 20, 2008 01:08 PM
b18greg
Oct 4, 2007 11:36 AM
