How to wire fan correctly?
I have a 90 CRX Si with a JDM D15B.. i picked up the car with the swap. The only thing that bothers me is that the Fan is connected so that when ever the car is turned on the fan is on. I would like to get it connected how it is supposed to be connected, for it to go on when it's supposed to... any one know how? Thanks
the temp coolant switch i think it is, its next to the oil pressure thingy on the back of the block under the intake manifold, check to see if the wires are connected thats how mine was then i connected them correctly
i just got done messen with fan wires but check up around the pasinger headlight and see if u have black/yellow and blue wire that is the fan wires myn were cut and tucked away i dono why but they were i just pulled a plug off my parts car and spliced it in and it works now
bignosewhipper
Jun 22, 2008 08:46 PM
Manual radiator Fan switch help! electronic gurus needed....tried search...but need more info\help..
Project_ED8
Dec 1, 2003 05:50 PM
