Temperature Gauge Problem
Old Dec 29, 2008 | 08:31 AM
NFRap1's Avatar
Default Temperature Gauge Problem
is there a specific ground for the temp. gauge? everything else in my cluster is functioning except that. so far ive changed the temp sensor below the dizzy and my thermostat. also this is my second cluster. any help? thanks honda-tech!
Old Dec 29, 2008 | 04:20 PM
NFRap1's Avatar
Default Re: Temperature Gauge Problem
Old Dec 29, 2008 | 05:59 PM
eda6's Avatar
if the temp gage wiring is grounded the needle rises to H and cluster damage could occur according to the helms manual.
check continuity from the sensor to the back of your cluster.
if you don't have continuity separate the 8 pin quick connect fitting on the passenger
side shock tower and recheck from the cluster and sensor back to the 8 pin connector.
Old Dec 30, 2008 | 07:35 AM
NFRap1's Avatar
ok ill try that, thanks
Old Dec 30, 2008 | 09:25 AM
HondaBryan43's Avatar
also check all the fuses. I had my temp gauge stop working and for some reason it was because my turn signal fuse blew. So just check that and see if that could be the reason and solution.
Old Jan 8, 2009 | 08:17 PM
NFRap1's Avatar
ive had it with my temp gauge not working and am ready to take drastic measures...is it possible for me to run a direct wire from the actual temp. sensor to the cluster and will it work fine?...my car is constantly running rich because the computer thinks the car is always cold and my mpg is terrible...ANY HELP?!?!?!
Honda_Accord
Mar 19, 2008 08:55 PM
rabbid sir
Jul 2, 2007 10:17 PM
5thgenallmotor
Dec 7, 2004 07:48 AM
projectTeG
May 10, 2004 10:31 PM
Rhetoric
Sep 14, 2001 06:55 PM
