HELP! it cranks but wont even hold idle at WOT
Old Dec 29, 2008 | 07:56 AM
soodominican's Avatar
Default HELP! it cranks but wont even hold idle at WOT
So yesterday i swapped my p75 head for a pr4 head because 4 valves were bent on the p75... we put everything back together and we checked pretty much everything and its all connected, we try to start it and she'll crank over and sometimes turn on ,when she does turn on ill hold her at wide open throttle and she wont even reach idle rpm's she'll just lump for a few seconds and then die, i dont have a check engine light or nothing and we messed with the dizzy at every position possible and she still wont start... we checkd to see if she was getting spark and we heard the spark plug wires shooting the spark to the spark plugs i dunno what the hell it could be, any1 got any suggestions? run into this problems before thanks
Old Dec 29, 2008 | 07:29 PM
Default Re: HELP! it cranks but wont even hold idle at WOT
anyone?
Old Dec 30, 2008 | 02:57 AM
~sp33~'s Avatar
EFB055
Have you checked your cam timing?
Old Dec 30, 2008 | 07:01 AM
Yup, everything is timed right.
Old Dec 30, 2008 | 08:10 AM
~sp33~'s Avatar
EFB055
If your getting spark and fuel, and your timing is right, then your compression is probably shot.
Have you had the cylinders pressure tested?
Old Dec 31, 2008 | 05:46 PM
how likely is it for my block to mess up in the couple of hours it took to swap a head?
shock.top.pat!
Honda Motorcycles
Jun 21, 2011 08:09 PM
93daintegra
Sep 16, 2008 01:21 PM
dashocker
Sep 1, 2008 03:26 PM
drumminforev
Jun 5, 2006 05:40 PM
