5th gear grinding
Old Dec 29, 2008 | 06:11 AM
94jdmlude's Avatar
Default 5th gear grinding
ok so every gear is good until 5th gear. goin from 4th to 5th gear to seems to grind no matter the rpm. only way to not grind is to go into neutral for a second or two before shifting. my clutch about to give or whats goin on?
Old Dec 29, 2008 | 06:22 AM
IN VTEC's Avatar
Default Re: 5th gear grinding
Synchro is losing its effectiveness. Replace the 5-R synchro set.
Old Dec 29, 2008 | 11:30 AM
Inextricabledrvr's Avatar
I am assuming this is the exact same thing for the 3rd-4th synchros? My third gear seems to be getting worse as I have to granny shift the heck out of it so, it won't grind.
Old Dec 29, 2008 | 02:00 PM
IN VTEC's Avatar
Yes. When you pull the transmission apart, check the synchro to gear clearance to determine how much braking material there's left on the synchro ring.
Old Dec 29, 2008 | 04:00 PM
Kronn 98SH's Avatar
I had a subtle clunk/grind going from 4th to 5th. It was cured after a clutch replacement and tranny flush.
Old Dec 30, 2008 | 02:32 PM
Redprelude98's Avatar
i have talked to many people who have owned a prelude and i have a 5th gen myself and i have the same problem, but many people have the same problem so i think that it might be a defect from the factory
Old Dec 30, 2008 | 02:38 PM
E-Money's Avatar
Mileage and year of transmission would help. 99 Prelude with 197k on transmission. Very smooth except third gear has some notches when engaging. But I would not make a big case about it, because its not constant and never effected my driving. Knocked on wood. ha
SoCalian_SD
Jan 18, 2009 07:43 AM
tegG2
Honda Motorcycles
Aug 21, 2005 01:08 PM
MTR.18
Mar 27, 2005 08:11 AM
missinghubcabs
Jun 25, 2003 03:41 PM
