Full All out D series Turbo kit!!! LOOK
I Have a Full turbo kit for a D series... i had it on my D15B7 motor and ran like a charm!!! The kit itself is about 4 months old.... not that old..... the Turbo does not have any Shaft play whatsoever and no leaks. IT GETS YOU THE BOOST YOU NEED.... Blow off valve is Awsome... it is an Authentic Turbo xs RFL.. REALLY LOUD. This kit i think is awsome because the fact that everything is included to run great on 8.5 psi. I will also include the Chipped and tuned P06 ECU.
KIT INCLUDES:
- T3/T4 Ar. 48 Compressor Turbo Charger (NO SHAFT PLAY)
- Turbo XS RFL Blow off valve
- Front Mount intercooler with all piping, couplers, and clamps
- 450cc Blue top Injectors with Resistor box
- all fittings needed, lines, and even Drain line for the turbo
- 3in Downpipe, will include brand new Flange with new Grade A bolts
- New Flex pipe on Downpipe (o2 sensor NOT INCLUDED)
- Oil Restrictor fitting
- XS power Turbo Manifold
- All Flanges needed
- External Wastegate with 8.5 spring
- Wastegate Dump tube
- Boost Controller Manual
- Chipped P06 ECU tuned with Chrome software and Annovative Wideband (will include chip for Stock injectors and the chip for 450 cc injectors..)
- Blox Vacum Manifold
- Might throw in a Greddy Turbo timer... if i can take it off in time
yup i think thats it... let me know what you guys think..... I WILL TRY NOT TO PART OUT BUT IF I HAVE TOO... THEN I WILL..... i would like to get close to $900 or soooo for everything... plus shipping but shoot me up with some offers... thanks and any questions please ask
KIT INCLUDES:
