Cranks over but won't start....
Old Dec 28, 2008 | 08:25 PM
91rexhf's Avatar
Default Cranks over but won't start....
My 91 hf shut off at a stop sign and will not start now any thing will help thanks? On a very tight budget anything I can do to see what it is before i buy a part?
Fuel pump?
Fuel relay?
Distributor?
Main relay?
Old Dec 28, 2008 | 08:35 PM
st_rage's Avatar
Default Re: Cranks over but won't start....
Sounds like the fuel relay. Listen for the fuel pump. It should come on for 1-2 sec when you turn the key to run from off. If it doesn't then the relay is a good bet. I'm sure there's a couple of dozen threads on it. It's a common problem on older honda's.
Old Dec 28, 2008 | 08:40 PM
EFRue57's Avatar
main relay and fuel relay are one in the same i believe
Old Dec 28, 2008 | 08:56 PM
91rexhf's Avatar
ok so are the main relay and the fuel relay the same thing?
Old Dec 30, 2008 | 11:35 AM
st_rage's Avatar
same thing
LS_teggy
Aug 5, 2010 08:41 PM
Kidnkorner
Apr 4, 2010 08:54 PM
Si-Samuri
29
Jun 19, 2008 05:48 PM
uszcrx
24
Sep 9, 2006 01:05 PM
RenoRacing
Sep 8, 2002 09:41 PM
