zc bogging problem
Old Dec 28, 2008 | 07:52 PM
efrunner09's Avatar
Default zc bogging problem
hey wassup guys i recently just bought this ef hatch with a zc swap already in it first had a broken tps so fixed that with new sparkplugs and short ram also running off down pipe. well any way if im cruising at about 4rpms then i go to mash the gas it just boggs and eventually will catch back up but if i mash the gas from zero it will go also will bog in neutral what u think plug wires,map sensor help plz
Old Dec 28, 2008 | 10:00 PM
kojack_0's Avatar
Default Re: zc bogging problem
what kind of zc?
Old Dec 28, 2008 | 10:37 PM
classdork987654's Avatar
my car is doing the same thing and what i did earlier was adjust the timing. it seemed to help a little. try hookin a timing light up to it and see if it is within spec.
Old Dec 29, 2008 | 02:59 PM
efrunner09's Avatar
ya i just been waiting for my buddy with a timing light to get back in town in like tommorow actually and its the dohc non vtec
Old Dec 29, 2008 | 03:11 PM
kojack_0's Avatar
its the ecu. get the pg7 or a pm7, preferably the pm7 its the stock one for that motor. or chip to a pm7 program.
after i swapped that happened to me. it feels like the gas just shut off or the clutch just engaged by itself. after i changed my ecu to a pm7 everything was great. pulls hard and great with gas.
Old Dec 31, 2008 | 02:18 PM
efrunner09's Avatar
i got a integra ecu
Old Dec 31, 2008 | 02:55 PM
kojack_0's Avatar
what integra? cause you cant use any integra ecu.
Old Dec 31, 2008 | 07:06 PM
GLI's Avatar
GLI
Check your tps and adjust it.
Old Dec 31, 2008 | 07:20 PM
thiendegigolo's Avatar
i had the same exact problem...your timing is off...get it retimed and your good to go
Old Dec 31, 2008 | 07:59 PM
ef8sleeper's Avatar
since you just fiddled with your tps i would think that is the problem.
sometimes the voltage reading wires are reversed on the tps.
when you open the trottle all the way, you should be reading 5.0 volts or something close with a voltometer.
if its backwards you will start at 5 volts and go down from there, causing the bog...
just depending on where you got the new tps from this may be the issue.
the fix might be as easy as switching the two outer wires connected to the tps.
hope this helps
Old Jan 1, 2009 | 07:26 AM
efrunner09's Avatar
ya just bought a new tps ima do a voltage check like u said and my timing but how do u adjust ur tps it dont just go on
Old Jan 2, 2009 | 07:34 AM
ef8sleeper's Avatar
yeah it goes on but the holes for the bolts should have oval notches this way as your reading it with the voltometer, you can slide it back and forth to get it right.
its just a tiny amount of movement but it makes all the diff
g/l
Old Jan 3, 2009 | 09:15 AM
efrunner09's Avatar
ya i got it working man sure was the adjustment but now when it still cold still wants to die wen u give it gas and also if like i drive it for awile then sum times it acts like it wants to die then works good again wierd i say
Old Jan 12, 2009 | 01:33 PM
efrunner09's Avatar
hey people well what i thought was wrong i still come across this backfiring bogging problem any other ideas changed tps adjusted it changed spark plugs and still on down pipe but peeps say it should bogg like it does the only way to stop the bogging is to push the clutch in otherwise car will just jump like crazy but its weird what yall think i guess ima just get a map sensor
Old Jan 12, 2009 | 01:51 PM
kojack_0's Avatar
i got one for sale. $30 shipped fairly new. its denso oem for a crx si. firewall mounted.
let me know.
Old Jan 12, 2009 | 02:10 PM
efrunner09's Avatar
yo man consider sold let me know email me are aim
Old Jan 12, 2009 | 02:37 PM
kojack_0's Avatar
aim - blackeg8
Old Jan 15, 2009 | 09:53 AM
efrunner09's Avatar
well guys i swapped the two wires goin to my tps and fixed the bogging problem but now when im cruising at high rpm like if it tap the gas and let off the car will kinda hop i d k it could be jsut rev limiter but not sure but really not a big deal
devonb456
Mar 19, 2009 06:23 AM
EFsideways
Dec 6, 2007 04:17 PM
integ u
24
Mar 11, 2004 05:01 PM
efjuice
Oct 7, 2003 10:48 AM
