SWAP to F22B DOHC
Honda Accord 94 CD3-EX JDM (~CD5 USDM) Automatic Transmission
i will be make swap my dead F18B (JDM SOHC no VTEC 125hp) -> F22B (JDM DOHC no VTEC 160hp from Honda Prelude 96 BB5 (obd2) )
i have F22B DOHC from Honda Prelude 96 BB5 (obd2) + ECU (from HONDA Prelude BA8 - obd1) + Wireless...
i need replace engine mounts?
what i need replace?
thanks
thanks
I think it should be a straight drop in, if not, you'll need the driverside mount. You might need to convert the engine harness into OBDI unless i'm wrong and can't read.
You are going to need a prelude drivers side mount, Convert your harness to ODB 1 if it isn't already.
It is pretty much the same thing as swapping in a H22.
I'll be doing this swap myself come the spring time
