I need your help !! Riverside ca
Old Dec 27, 2008 | 11:22 PM
Peruviann83's Avatar
Default I need your help !! Riverside ca
LF SOMEONE IN LOCAL CORONA AREA TO HELP ME WITH SOMETHING (BRAKES) PLEASE MESSAGE ME QUICK EASY MONEY
Thank You
Old Dec 28, 2008 | 12:01 AM
Default Re: Neeed Youuuur Helpp !! Please
please helpppp
Old Dec 28, 2008 | 12:03 AM
PYDB8-R's Avatar
How is anybody supposed to help you when your not telling them exactly what the problem or symptom is?
Old Dec 28, 2008 | 12:09 AM
naallday's Avatar
Banned
x2
Old Dec 28, 2008 | 12:13 AM
when i get in my car with it off brake pedal goes all the way down like it has no pressure the more i pump it the pressure eventually comes back
Old Dec 28, 2008 | 12:24 AM
naallday's Avatar
Banned
bleed ur brake lines
Old Dec 28, 2008 | 12:28 AM
Thanks i hope thats it is there any way i could check visualy if the mc or booster is gone someone got me scared saying it could be ur brake booster and now im tripping cause i cant afford to do that
Old Dec 28, 2008 | 12:37 AM
naallday's Avatar
Banned
chek if ur fluid level stays the same but sounds like u gotta blled ur brakes try that and lmk if it fixes ur problem
Old Dec 28, 2008 | 01:21 AM
Hamstr323's Avatar
don't post this here post in the forums not in the forsale section
Old Dec 28, 2008 | 01:38 AM
Dark Star's Avatar
LOL , Relax he's just looking for help !!!!
Old Dec 28, 2008 | 03:28 AM
thanks
hopefully it works when i change the MC i need my car up and running for new years !!
Old Dec 28, 2008 | 03:47 AM
virdizzeripsta's Avatar
Originally Posted by Peruviann83
thanks
your valve in the brake line that goes to the manifold? maybe, switch it and see wat happens
Old Dec 30, 2008 | 11:50 PM
ok so i changed the mc and it helped a bit but still doing the same thing
Old Dec 30, 2008 | 11:55 PM
ekb16a's Avatar
i AIM U ILL FIX UR PROBLEM
Old Dec 30, 2008 | 11:57 PM
jdm_bones's Avatar
I can fix it....I can write a very long post on how too, but if you aren't good with cars I can't help that....Brakes can be hard to read sometimes, and need to be adderessed by a real Tech.
Old Jan 3, 2009 | 05:16 AM
bummmp
Old Jan 3, 2009 | 07:27 AM
to the top ppppppleeeeaaaassseee
Old Jan 3, 2009 | 08:48 AM
bummmp
Old Jan 3, 2009 | 09:04 AM
Default Re: I need your help !! Riverside ca
bummmp need help with brakes PSTTT
Old Jan 3, 2009 | 10:24 AM
bummmp this ****
Old Jan 3, 2009 | 11:02 AM
to the top
Old Jan 3, 2009 | 11:05 AM
TIMMY4TOES's Avatar
1. one of your brake lines could be leaking
2. calipers can be f'ed up
3. you do not know how to properly bleed all 4 brakes( even one brake that has air will cause the pedal to stink)
4. you could also have got a defective mc booster( this has happened to me b4)
hopes this can help a little
Old Jan 3, 2009 | 01:36 PM
bummp de bump
Old Jan 3, 2009 | 09:31 PM
bump this to the top
Old Jan 3, 2009 | 10:20 PM
monotech's Avatar
Master cylinder is usually the cause of that cause signs of a bad brake booster is stiff pedal pressure. You should also check for leaks on your brake lines. Bleeding procedure when you change your Master cylinder is start off with the brake caliper farthest from the master cylinder. Make sure you bench bleed the master cylinder before you reinstall it.
Good Luck!
