how do i remove the front bumper n filler piece off my 90 civic hatch?
i need to remove it to replace my headlight assembly on the passenger side cuz my corner light on that side doesnt sit in right and it flaps around when im on the freeway. anybody got a picture diagram or something on how to remove this ****?!
There are large phillips screws directly under front hood lip in front of the radiator, there is one lower in the center of the grill as well, should be 5-6 total if I recal. Next you will remove the two phillips screws in the front of the wheel wells where the fender meets the bumper. You also will want to remove the turn signals located in the lower front bumper, thats it. There is 10mm bolts holding the headlight housings in place, the lower ones can be tricky to get to.
Kirk R
Kirk R
**FRONT BUMPER**
- First remove the Front Bumper Lights.
- Remove the 2 phillips screws on the inner wheel well of the bumper (in front of tires 4 total).
- Remove the 10mm Bolts holding the Bumper to chassis (2 behind each bumper light).
**=Bumper should just pull right out!=**
**FRONT BUMPER FILLER**
(requires the front bumper to be removed first)
- Remove the corner blinker lights
- There are 2 10mm Bolts holding the bumper filler on each corner.
- Remove the 10mm bolt by hood latch
**=Now removeable, just pull.=**
i did mine on friday...simple...if need a visual aid...download the manual
http://hondatech.info/downloads/Auto/Manuals/CRX/
the 307.42mb crx service manual...but it doesn't show you that you have to take off the garnish above the bumper...but that was easy enough to take off
udm_motorsport
May 6, 2004 08:36 AM
rasta420
Jul 3, 2002 08:50 PM
