90-91 lx 4 door EF seatbelt question.
Old Dec 27, 2008 | 05:13 PM
graveltravel2's Avatar
Default 90-91 lx 4 door EF seatbelt question.
ok, you know the "automatic" seatbelt thingys that slide up and down the front doors?
mine isnt working on my 90 lx.
is there any fuse to check or anything?
i cant find **** on these.
TIA!
Old Dec 28, 2008 | 08:03 AM
Default Re: 90-91 lx 4 door EF seatbelt question.
ttt
Old Dec 28, 2008 | 09:26 AM
aztecracer1's Avatar
There will be two fuses on the positive battery cable right at the terminal that are for the auto seat belts
Old Dec 28, 2008 | 01:41 PM
ahhhhhhhh ty ty.
what are the sizes?
Old Dec 28, 2008 | 03:04 PM
ok, i replaced the 30 amp fuses.
still nothing.
but the old fuses were sooo corroded in the fuse holder...
so i have no clue if the thingy on the battery is actually still good.
Old Dec 28, 2008 | 04:02 PM
d16man's Avatar
there is a conection under ur seat make sure they are conected, i kno when i had my 4 door they didnt work and i had to conect them!
Old Dec 28, 2008 | 06:22 PM
xci_ed6's Avatar
lifetime warranty. Take it to Honda.
Old Dec 28, 2008 | 06:51 PM
sde780's Avatar
^ Honda tries very hard to weasle out of it. They wanted to charge me $60/hr to diagnose or something, then if it was covered I'd pay nothing. If it wasn't I'd have to pay out my *** for all the fee's.
What I did was push the slider to the position where it's supposed to be when you're driving, then pull the fuse.
Not enjoying the chimes? behind the center console there's a black box, it's rectangular. Open it from the passenger side (unscrew the plastic screw and pop out clip), pop the lid off, and pull out the connector closest to the engine.
There should be 2 connectors in there, you wanna pull the one that's farther from you. This stops the chimes.
Old Dec 31, 2008 | 08:25 AM
well, theres no chimes. i havent checked under the seats yet.
this car is full of demons.
i believe it has the typical bad main relay or bad ignition switch. fockin POS.
Old Dec 31, 2008 | 10:13 AM
ArtyG's Avatar
I rewired mine in my '90 EX sedan.
I just cut the wires...checked for corrosion/continuity, and put in two new fuse holders and fuses and wired them in and mine worked again.
Old Dec 31, 2008 | 12:48 PM
Sobe_Death's Avatar
I had to do the same on mine. The fuse box at the battery had degraded so bad it fell apart when I pulled the terminal. After redoing it the belts moved faster and quieter than they ever had before.
Old Dec 31, 2008 | 12:51 PM
well, the wires under the seats are connected.
no dinging or anything.
pos ef
90EFCruiser
Nov 4, 2009 12:44 AM
07FG2
Jan 16, 2009 04:39 AM
black0hatch
Oct 7, 2007 12:09 AM
wood 1
Jul 7, 2007 03:21 AM
illnino
Dec 17, 2002 07:25 PM
