5 lug quesion,axel question?
Old Dec 27, 2008 | 09:59 AM
wannabe_itr's Avatar
Default 5 lug quesion,axel question?
i have a qiuck question...
i bought a set of 5 lug from a member on another site for very cheap becuase everything thing in the front needed to be changed...
so i bought new lower ball joints, new hubs, hub bearing, rotors and calipers.....
so i install the 5 lug and i hear a humming noise, sort of the kind the kind that u get when u have bad wheel bearings.... but it cant be becuase the bearings are brand new....
so my question is can this noise be comming from the axel... the axels are bad and they need to be changed.. but will tem being bad make this noise.
Old Dec 27, 2008 | 10:45 AM
94rs-turbo's Avatar
Default Re: 5 lug quesion,axel question?
Check and see if the rotor is rubbing against the caliper bracket
Old Dec 27, 2008 | 11:18 AM
krucial7integra's Avatar
axles don't make humming noises, could be your wheel bearings which is a cheap part to replace anyways, $35 or so at the local auto store.
Old Dec 27, 2008 | 01:48 PM
it was aftermarket buy it was a higher quality one... i paid 78 bucks for each
Old Dec 27, 2008 | 01:49 PM
there is some marks on the rotor it could be this.... how would i fix this?
Old Dec 28, 2008 | 03:56 AM
anyone?
Old Dec 28, 2008 | 08:24 AM
touchmyHONDA's Avatar
go to an alignment shop... see if something off balance... diagnose from there
FRKWOO
Mar 18, 2010 10:43 PM
tealchief
15
Mar 17, 2010 07:40 AM
ThefirstPACT
Suspension & Brakes
11
Oct 17, 2005 05:04 PM
Nova_Dust
Jan 17, 2005 06:36 AM
philosofy1
Suspension & Brakes
Jan 6, 2005 11:22 PM
