94 Integra LS Door lock problem. Please help, CAN'T OPEN DOOR!
Old Dec 27, 2008 | 08:39 AM
Acurazor's Avatar
Default 94 Integra LS Door lock problem. Please help, CAN'T OPEN DOOR!
Hey I just recently bought a 94 LS 2door. Guy who I got it from didn't know anything about it so it's usless to ask him. Anyway doors werent locked, so I get home. Lock the doors, next morning they wont unlock with the key. I go to the passenger side and I got that door open. Once inside I try to unlock it and it unlocks for a split second then locks agian on it own. unlock.......lock. But the drivers doesn't unlock all the way, it's like something is holding it up inside. But I can't get the panel off cause the door is stuck shut. Is it a relay or something? Never had a problem like this. Someone has to know something abou tthis.
Thank you H-T!
Old Dec 27, 2008 | 11:00 AM
Acurazor's Avatar
Default Re: 94 Integra LS Door lock problem. Please help, CAN'T OPEN DOOR!
bump!
Old Dec 27, 2008 | 11:20 AM
dubzz24's Avatar
Try pulling the power lock fuse? Then see if you can at least get the door open so you can get the panel off.
Old Dec 27, 2008 | 03:23 PM
Acurazor's Avatar
will do. anyone else?
Old Dec 27, 2008 | 06:13 PM
fcm's Avatar
fcm
Old Fart
Are they stock power door locks, power door locks on a 94LS were an option, is there a power door lock switch up by the drivers inside door handle?
They sound like stock door locks, [or aftermarket central locking power door locks.
Drivers door actuator, [door lock motor] is stuck/binding in the locked position putting it's internal switch in the lock position, reason pass. door can be unlocked but will relock again, [signal from drivers door actuator telling "Power Door Lock Control Unit" to lock the doors.
Pull fuse 6 - 20A, [hot at all times] in under dash fuse box.
If the above will let you open the drivers door, pull the door panel before you do anything else.
It is possible that lock linkage is bent and that is why the drives door will not unlock/open, in which case pulling the fuse may only prevent the pass. door from re-locking, but as the signal to lock goes to both/all actuators, you may be able unlock the drivers door with the key or the manual lock switch.
If lock linkage works normally with key or manual switch when fuse is removed but binds up again if fuse is reinstalled and doors locked, [reason to remove drivers door panel first chance you get] replace the drivers power door lock actuator. 94
LT Link
Nov 5, 2019 01:17 AM
Loy
Nov 22, 2013 05:29 PM
EG94dude
Feb 16, 2010 05:44 PM
Tonyl507
Mar 9, 2007 06:23 AM
97itr86
Dec 31, 2004 02:06 PM
