Doing some swaping! need some help!
Old Dec 26, 2008 | 11:03 PM
94EGKUSH's Avatar
Default Doing some swaping! need some help!
Ok well im helping my friend do a mini-me swap.
i was wondering if you guys could help.
Specs:
1990 Civic Dx.
Carburetor d15b(not JDM?) No Vtec.
I have a 92 spec D15b Vtec and we want to put my d15b head on his block thus creating a mini-me.
but i have a obd-1 and hes is obviously obd-0. Im giving him:
head
Intake mannie
throttle body
Sensors
Distributor
Injectors
Fuel rail
i was thinking on doing plug swaps on the dizzy and getting a obd-0 vtec single cam ecu.
also what kind of things do we get like:
head gasket
headstuds(can we reuse? car never over heated)
Oil
coolant
ect.
Help Us out!
Old Dec 26, 2008 | 11:14 PM
dephtone's Avatar
Default Re: Doing some swaping! need some help!
Well considering the dx is 2 injectors (duak point FI) instead of 4 injectors (mpfi) you will have to run 4 extra wires from the ecu to control the extra injectors.
Honestly if you have an obd1 ecu and dizzy already...spend the extra 150 bucks and do it this way http://www.j-k-tuning.com/obd0-dpfi-...ess-p-306.html
Order that so you don't have to guess at the wiring or hack up the existing harness in the car. This allows you to run a p28 which is more readily available then a vtec obd0 ecu..
Doing a mini me swap you will need to get different headstuds. First of all you really want to avoid using stock headstuds as they are TTY( Torque to Yield) which means they can stretch even if the car hasnt overheated.
Old Dec 27, 2008 | 10:08 AM
94EGKUSH's Avatar
Ok So can what kind of things do i get.
Like timming belt, head studs, and Head gasket?
So just wire pins and get the rywire things?
and this swap can be done?
Old Dec 27, 2008 | 04:39 PM
94EGKUSH's Avatar
Old Dec 27, 2008 | 09:38 PM
94EGKUSH's Avatar
Old Dec 28, 2008 | 02:08 PM
94EGKUSH's Avatar
help?
Old Dec 28, 2008 | 02:55 PM
94EGKUSH's Avatar
help?
Old Dec 28, 2008 | 06:17 PM
94EGKUSH's Avatar
anyone?
Old Dec 28, 2008 | 08:48 PM
sgallagher's Avatar
obd0 vtec ecu???(other than PR3, PWO)
Just convert to OBD1. More tuning capabilities anyway.
Old Dec 30, 2008 | 12:39 AM
94EGKUSH's Avatar
yea i was searching all day and night i got all my info thanks tho
Zack Gunther
13
May 10, 2013 08:42 AM
delsol92
Nov 21, 2011 10:30 PM
nickeynick
Jun 29, 2009 08:52 AM
cars101
Jul 11, 2007 05:55 AM
29psiHybrid
15
Jan 30, 2002 10:22 PM
