Tire size question?
Old Dec 26, 2008 | 07:04 PM
88turdbucket's Avatar
Icon2 Tire size question?
SO i was wandering if anyone knew, if i could stick 155/80/13 on my stock 13" wheels i know the call for 175/70/13 but they have a good sale on some khumo 155/80/13 tires for 15$ a piece. thanks for any help..
Old Dec 26, 2008 | 07:14 PM
exz0n-.-'s Avatar
Default Re: Tire size question?
eek.
80 series are like monster truck tires man.
i wouldnt go any bigger than 70 series which is what im running
Old Dec 26, 2008 | 07:16 PM
EFRue57's Avatar
Originally Posted by exz0n-.-
eek.
80 series on the 175 maybe but not on a 155. remember the 80 number is not an actual height but a percentage of the width of the tire.
should be okay. they're only slightly taller than the 175/70's
Tire 1 - 175/70R13 Tire 2 - 155/80R13
Section Width: - -
Section Width: 6.88 in 175 mm
Section Width: 6.10 in 155 mm
Rim Diameter: - -
Rim Diameter: 13 in 330.2 mm
Rim Width Range:
Rim Width Range: 4.5 - 6 in
Rim Width Range: 4 - 5 in
Overall Diameter: - -
Overall Diameter: 22.64 in 575.05 mm
Overall Diameter: 22.76 in 578.10 mm
Sidewall Height: - -
Sidewall Height: 4.82 in 122.42 mm
Sidewall Height: 4.88 in 123.95 mm
Radius: - -
Radius: 11.32 in 287.52 mm
Radius: 11.38 in 289.05 mm
Circumference: - -
Circumference: 71.12 in 1806.4 mm
Circumference: 71.50 in 1816.1 mm
Revs per Mile: -
Revs per Mile: 918.7
Revs per Mile: 913.8
Old Dec 26, 2008 | 07:27 PM
so for 15$ it isnt so bad, i know they are a little taller but i need something because my 17" are gone and until i can get some smaller wheels and tires these should do for awhile.
Old Dec 26, 2008 | 08:24 PM
sinepome's Avatar
is 175 the widest that can fit, or is made? not to thread jack but i thought this might be easier than making a new one...or searching...
Old Dec 26, 2008 | 08:39 PM
SSGojeta's Avatar
i have 195s but it depends on the width of the rim
GsDAteg
Nov 30, 2008 04:21 PM
hondaracin24
Jun 22, 2005 05:05 PM
MidNit
May 23, 2003 07:35 AM
anjapower
Dec 9, 2002 08:16 PM
Mr. Softee
Dec 26, 2001 05:03 PM
