Fuel injector question
H22s use low impedance injectors on OBD1 ludes.They need a resistor box. 92-00 civics use saturated injectors. They do not need a resistor box. But OBD1 b16 injectors will fit on a OBD1 h22.
I need 450cc injectors and I found some that are listed for OBDII B and D series and just wondered if they would work in an OBDII H series
He is looking for 450cc injectors but found some for a B series. He just wants to know if B and H injectors are interchangeable.
OP. Yes, you can use em. As long as they are of the same OBD or else the clips won't be the same. If you are obd1, as stated before, they run off a resistor box stock.
Edit: Are you running OBD1 or OBD2? Are the injectors you are looking at peak and hold or are they saturated?
i will be running my stock ecu (p2t obd2), coz were we are, we have its called air care. if you dont pass the air care you cant renew your insurance. anyways, i have the fuel injectors now it came out of 1999 honda prelude sh and its saturated
hmm... 290 is a minor upgrade from stock.
i am finishing a B20vtec and using dsm 450's. don't know how big your build is but you might wanna make sure with your tuner if they will be ok.
my tuner did prolly 13 lsvtec and min. of 290cc itr top end b18c bottom end with 11.5:1 ratio and over bore to 85mm all n/a. hes done b20s with rc310cc unless your running turbo with it then you need atleast 450cc min. 450s too much for n/a.
spoonzdelsol
Jan 23, 2006 04:03 PM
