my clutch pedal makes noise when i push it in how do i fix it
Old Aug 4, 2002 | 05:10 PM
01-0720's Avatar
Default my clutch pedal makes noise when i push it in how do i fix it
it used to do it just somtimes now all the time do i lube somthing or take somthing off an squirt wd40 in there i squirted some wd40 in the general area of the clutch pedal an it seemed to help for a little while please help
eric
Old Aug 4, 2002 | 05:36 PM
JohnnyBoy's Avatar
Default Re: my clutch pedal makes noise when i push it in how do i fix it (01-0720)
It may be in the slave/clutch fork area also. Seems to be pretty common for squeaks. Had it in mine and it drove me nuts till I finally found it.
Old Aug 4, 2002 | 07:01 PM
01PYITR's Avatar
Mine squeeked right before it went, so becareful.
Old Aug 4, 2002 | 09:31 PM
01-0720's Avatar
Default Re: my clutch pedal makes noise when i push it in how do i fix it (01PYITR)
it squeeked before your clutch went, should i take it to acura an have them check it out, an by the way i have a aem cold air apex n1 exhaust an skunk2 coilovers will this stuff void my warenty , the dealership i bought the car from said it wont (i bought it with the intake an a diffrent exhaust but it still had exhaust, should i return the car back to stock before i take it in
Old Aug 4, 2002 | 09:37 PM
1033's Avatar
HEY I HAVE THE SAME PROBLEM
i just ignore it
but does it really means the clutch is going?
i have only 38000KM on my clutch for my 2000 type r canadian
Old Aug 4, 2002 | 09:38 PM
hadboosttroy's Avatar
i believe the only way it can void your warranty is if it is directly related to the problem you are having.
Old Aug 4, 2002 | 10:22 PM
OutLaw MR's Avatar
your squeak is most likely coming from the trans clutch release fork/bearing need to lube the main shaft with high temp grease and no the dealer wont void your warranty for simple bolt on mods.
Old Aug 5, 2002 | 07:48 PM
01-0720's Avatar
Default Re: my clutch pedal makes noise when i push it in how do i fix it (OutLaw R)
thanks for the help, if i take the car to the dealer will they cover this under warrenty
Old Aug 5, 2002 | 09:25 PM
OutLaw MR's Avatar
yup for sure
Old Aug 6, 2002 | 06:35 AM
01-0720's Avatar
thanks again
iLOVEmyEMone
Oct 28, 2005 05:31 PM
megaman096
Nov 8, 2004 11:26 AM
SAPPHIREblue6SPEED
Sep 13, 2003 12:25 AM
SublimeStyles
May 18, 2003 04:14 PM
Honda F1
Apr 24, 2002 05:37 PM
