89 dx clutch/ axles work with a cable Si tranny?
Old Dec 26, 2008 | 04:02 PM
mesa50w's Avatar
Default 89 dx clutch/ axles work with a cable Si tranny?
I picked up a 89 dx HB about 2 months ago to be a daliy driver so the STi can get a cage in it for trackdays. the motor that came in it started smoking pretty bad so I thought what a perfect time to do a d16z6 obdI swap with a si tranny. The clutch and axles that are in the car now are only a month old. Can i use them on the Si tranny? I was told the Si tranny is out of a 90 si. thanks
Old Dec 26, 2008 | 04:31 PM
hondacivic90zc's Avatar
Default Re: 89 dx clutch/ axles work with a cable Si tranny?
as long as you use the clutch disc, pp, and flywheel from the 89 it will work fine. I would take the clutch disc and make sure it splines onto the si tranny before you go to put it all together though.
EDIT:
And yes the axles will work fine as well
shyguy4no1
Feb 12, 2010 12:42 PM
Xemu
Sep 19, 2006 09:10 PM
crooked muffler
Aug 10, 2004 07:49 PM
92hybridhhatch
Apr 6, 2004 05:37 PM
88rexdxa6ed
10
Apr 17, 2003 12:36 PM
