OBD2 pin into OBD1 connectors??
Old Dec 26, 2008 | 03:51 PM
laziebun's Avatar
Default OBD2 pin into OBD1 connectors??
Can i put OBD1 ECU connectors on an OBD2 engine harness and use the same pins? So that i dont have to use the jumper.
Old Dec 26, 2008 | 04:10 PM
iwanttokillgod's Avatar
Default Re: OBD2 pin into OBD1 connectors??
if you know how to wire it in you can
Old Dec 27, 2008 | 05:27 AM
Blown90hatcH's Avatar
Stop spreading information if you do not know. That is wrong.
The OBD2 female pins are too large and use a different locking mechanism to fit in the OBD1 male plugs. The only thing you can do is to crimp or solder the OBD1 pins onto the wires of your car and plug them in. Or the obvious of soldering the wires on, etc.
Old Dec 27, 2008 | 07:15 AM
laziebun's Avatar
yeah i found a set of OBD1 harness connectors and im just going to solder the OBD2 wires to the OBD1 wires.
Old Dec 27, 2008 | 10:29 PM
this guy is a dumb *** i assumed that the op woul cut and solder them together
Old Dec 28, 2008 | 12:31 AM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
try here, http://technet.ff-squad.com/
Old Dec 28, 2008 | 03:22 AM
laziebun's Avatar
Thanks!
kornkid21792
May 9, 2010 02:35 PM
crx18c1
Nov 5, 2007 07:43 AM
Cyphear
Jul 13, 2007 03:58 PM
crazyfiz
Jul 6, 2006 02:11 PM
HmgLauj69
10
Aug 11, 2005 05:27 PM
