Honda S2000 Honda S2000
Hardwired Valentine One on an S2000!
Old Dec 26, 2008 | 01:59 PM
DC2B18cya's Avatar
Default Hardwired Valentine One on an S2000!
Hi, can someone show me a links or picture, how to hook up the radar? thanks 07 Honda s2000
Old Dec 26, 2008 | 02:03 PM
HondaKyle's Avatar
Default Re: Hardwired Valentine One on an S2000!
You might have better luck in this area of Honda Tech.
Audio / Security / Video
https://honda-tech.com/forums/audio-security-video-27/
Old Dec 26, 2008 | 02:17 PM
S2KFTW's Avatar
it's a pretty easy job. the interior fuse box is on the driver's side under the dash and has a couple of accessory positive terminals, there's also a factory ground point near there which is convenient use a multimeter to find the post that's only on when the key is on the on position and you're good to go.
then run the power line up the A pillar and across to the V1. I pulled my A pillar cover off and that made the job simple, it just snaps off, start at the top and b nice to it to get the wire the rest of the way to the V1 go across the top and just tuck the wire behind the cover. actually start at the V1 and work your way back to the power source, then you'll have your slack down where you can hide it.
Old Dec 26, 2008 | 02:23 PM
DC2B18cya's Avatar
Right I knows its a simple job and I already took off the A pillar and run my wires there too already and I noticed that the s2000 have the 3 plug under the dash But I just want to make sure to see how yall guys hooking it to? plus the ground wire. anybody can show me some picture's that would be awsome.
Old Dec 26, 2008 | 02:25 PM
HondaKyle's Avatar
you should take pics of it all and make it a DIY! Im sure other people would like to know.
Old Dec 26, 2008 | 02:28 PM
DC2B18cya's Avatar
LOL Yes! that would be Nice Huh? Yeah I think they had one on s2ki.com but it won't load any pix's...=(
Old Dec 26, 2008 | 02:35 PM
S2KFTW's Avatar
if it wasn't pitch black out already I'd take some pictures, maybe tomorrow I can get some pictures of what I did.
Old Dec 26, 2008 | 02:36 PM
HondaKyle's Avatar
That is why you are about to make the new better one.
S2KFTW's Avatar
for the ground look for a 10mm bolt with a bunch of factory ground wires already going to it. it's on the fender wall to the left of the fuse box.
Old Dec 26, 2008 | 04:07 PM
CHONCH2's Avatar
there is a nice DIY on s2ki.com that shows the 10mm ground bolt and which slot to tap into on the fuse block. i did mine that way. very easy and painless! no cutting/splicing wires.
my v1 resides just to the left of my rearview mirror, you can't even see it from outside of the car. only drawback is that i can't use my sun visor, but i'm too tall for that **** anyways.
Old Dec 27, 2008 | 09:27 AM
CHONCH2's Avatar
just saw this at the top of the page as a sponsor ad:
http://www.mgtmotorsports.com/?gclid...FSAUagod5FUnEA
dunno if it will work with out rearview mirror arm, but a very cool idea nonetheless
Old Dec 27, 2008 | 10:09 AM
S2KFTW's Avatar
my buddy showed me that, it's pretty cool. it would probably work on our mirrors but the suction cup mount works so well I figured why pay the money.
the way they show the V1 is where I have mine mounted. nice and high but doesn't block the visors and is still in reach to hit the mute button.
Old Dec 27, 2008 | 05:02 PM
sideways.dan's Avatar
theres wiring instructions somewhere online my tip is you don't need to take the plastic off the pillar you can just push/tuck the wire in
i got an $800 ticket the other day I might send mine back
Old Dec 29, 2008 | 06:40 AM
White Smoke's Avatar
i my honda
Global Mod
I do not like radar detectors mounted at the top of the windshield on the S. Too easy to steal when the top is down and it sticks out like a sore thumb there. I mounted mine in the center down low, and tucked the wire behind the dash. I have the concealed display mounted to the left of the radio door, in the perfect spot to reach with out taking my hand of the shifter.
Old Dec 31, 2008 | 02:27 PM
ReddotsS2K's Avatar
hardtop is pretty good as withstanding theives
b16rex_02
Feb 22, 2014 04:42 AM
vrrodri
Jul 11, 2012 06:33 PM
ChiLS
Jul 20, 2008 12:27 PM
5G_Vtec
Mar 5, 2007 05:35 PM
doublethink
Jan 12, 2005 03:01 PM
