Why am I still smoking?
White smoke above 4500rpm. Recording events and procedures taking place for people with smimiliar problems.
Since the OP was made I have taken the car in for a new turbo timer(buddy club is worthless) and had my local shop look at the smoke I refer too. Shop manager thinks it is an engine problem even on a newly built block. Every measure is being taken to fix the problem and pinpoint the problem over an extended period of time with me driving like a grandpa and updating this thread in the solutions performed in order to fix a smoking engine. Oil ring seals, bad job at putting the engine together, gasket problems? We will see...
yeah as soon as i saw cometic i was skeptical. I would stick with an Oem 3 layer and what are you using for head studs/bolts? If they are oem bolts have you been replacing them or reusing them? Also have you checked straightness of the block deck?
is this going to work properly with 9:1 low comp pistons?
Why the hell after I spool up do I have white smoke coming out of my exhaust when I shift gears...
either way something is leaking. lol
but i wouldnt say cometic is trash. I hadnt ever had a problem with them. ran one for a very long time, hassle free.
And are you loosing water/coolant too?
not that I've noticed and if I have it's a very small amount for me not to notice.
Changed my oil, replaced all gaskets except for head gasket in beggining of next year. While I have the B16A2 head removed I will have it milled. Why the hell after I spool up do I have white smoke coming out of my exhaust when I shift gears? Engine is built and I can't figure out if changing the headgasket is even nessecary although I do see a slight leak near the lower left corner of the first piston area near the tranny. The compression is 9:1 with a cometic copper head gasket and my friend seems to think this will help. Am I going in the right direction? The car still hasnt been tuned yet and isn't running hondata yet either which I have planned after the head gasket replacement.
I guess it has to be the head gasket due to the overheating if I "push" the car and come to a dead stop in a parking lot or something. I will have to give it gas and float the rpms around 1300 to keep it from getting hot even with the fan on.
I just wanted a daily driver turbo B16 and it's starting to turn into a major pain in the ***.
You are PUSHING the car boosted when it hasnt been tuned yet, mistake numero uno (thats number 1)
You probably havent retorqued the ARP headstuds after heat cycling them, Mistake numero dos
Make sure your drain line and feed line isnt kinked.
You wanted a safe daily driver but you have neglected to tune the car, go figure.
swap the headgasket for an OEM HONDA headgasket, tq it down. Let the car heat cycle a few times, retorque headstuds, TUNE, do NOT PUSH THE CAR ON A BASEMAP
1.oil return (kinked or ran to were oil can backup )
2.ballbearing turbo? if so do u have the proper jeted oil supply fitting
3.valve seals or rings test by a compression test and leak down
4.seals in turbo (oil sometimes will seap out from between the cartridge and housing)
5. head gasket is possaible but no likely
6. tune that thing beatin on a basemap is not a good idea to rich can wash rings to lean can burn up a piston.which both will cause it to smoke.
Good luck , please no returned comments on this post
lets recap
Or you can buy a Crome PRO ecu for $180 an go tune it next week
No that's cool I can take constructive criticism. Yea you're right I guess I've been lucky not causing any dmg I can see yet by popping the hood. I'll keep it under 3k. But can I tune it before I buy an EMS or do I have to buy one first? I already called my local shop that works with Hondata, chrome, and AEM and they told me I can bring it in now to get tuned. The only thing I have on the car is the apex V-AFC. I made an appointment for next week. I just hope I don't run out of "extra" money before we figure out the exact problem but income tax and my rent being cut in half for january and february will help along with a small winter bonus I should be getting in february.
What injectors are you running, what map sensor?
you CAN tune with a VAFC but not fully. If you have bigger injectors youll need to run the hack. Missing link, etc.
If you are running the hack you can get a decent tune to make you last till you get hondata.
Personally id sell the VAFC for $100 an PM me i can sell you a CROME PRO ecu ready to go thta you can get tuned asap, you can still use that ECU later on to run Hondata S200 if you so desire, but for what you are trying to do Crome Pro is fine
need to know about your setup,
im probably just goingto run hondata coupled with the V-AFC since I know nothing about wiring and it would be more of a hassle than help TBH. I'll look at the prices of the Hondata s200 and work with my shop to see what we can work out. is chrome pro more aimed for daily driving use? dont answer that if you don't want to I can find out for myself when im not being lazy
Ok there is 2 types of Hondata. There is S200 and S300.
Now, S200 is no longer made but you can pick one up used easily for around $200 with boost option. You will still need a chipped ECU to work with the Hondata S200. Expect another $150-160 for a chipped ECU in addition to the Hondata S200 box.
S300 is a complete board that you solder into your existing OBD1 ECU, S300 is MSRP $595, then you need an OBD1 ECU to put it in, and prob pay someone to put it in thats around another $80.
Now both of those are still without TUNING.
or you can buy a Chipped OBD1 ECU for $160 with Crome Pro already loaded on it, and drive to your tuner an tune it, done.
Crome Pro is fine, its capable of supporting 500whp, ive done it on 1000 different cars. Hondata S300 is a great system, and i reccomend it for the higher hp cars, but for what you are doing, the Crome System suits your needs much better, it does everything S200 and 99% of what S300 does. and its far cheaper.
youll want to ditch the VAFC no matter what as it is rendered useless with the other tuning systems
you are way off lol
The AFC pretty much just becomes an RPM display, thats it. Its pretty useless at that point
I can name multiple people that have held a cometic gasket for more than a season with 800+ whp. Maybe before you try to pin point a headgasket, why don't you double check your super amazing machinist? Thanks.
